HIS ATI Radeon HD 4870 1GB IceQ4+ Turbo
Written by Tim Smalley
January 19, 2009 | 15:11
Tags: #1gb #4870 #benchmark #bundle #comparison #cooler #evaluation #hd #iceq #iceq4 #information #performance #radeon #review #rv770 #temperature #turbo
Companies: #ati #his #test
Crysis
Publisher: Electronic Arts
Crysis is seen by many as the poster boy for DirectX 10 and it will make your system cry, quite literally – it’s a monster! It doesn’t come as much of a surprise then, that the graphics are something special – they’re above and beyond anything we’ve ever seen in a PC game.
We tested the game using the 64-bit executable under both DirectX 9.0 and DirectX 10 with the 1.21 patch applied. We used a custom timedemo recorded from the Laws of Nature level which is more representative of gameplay than the built-in benchmark that renders things much faster than you're going to experience in game. We found that around 27-33 fps in our custom timedemo was sufficient enough to obtain a playable frame rate through the game. It's a little different to other games in that the low frame rates still appear to be quite smooth.
We set all of the in-game details to High and forced 8x anisotropic filtering in the driver menu as there is currently no support for it in game. We tested at 1,280 x 1,024, using 0x, 2x and 4x anti-aliasing, 1,680 x 1,050 using 0x and 4xAA, 1,920 x 1,200 using 0x and 2xAA and 2,560 x 1,600 with 0xAA and 2xAA. By extensively testing using anti-aliasing in very high resolutions in conjunction to Very High quality, we'll be pushing even the bleeding edge hardware on test to the limit.
HIS ATI Radeon HD 4870 1GB IceQ4+ Turbo Crysis - DirectX 10 HIS ATI Radeon HD 4870 1GB IceQ4+ Turbo Crysis - DirectX 10
Crysis
1,280 x 1,024 0xAA 16xAF, DirectX 10, High Quality
  • Nvidia GeForce GTX 280 1GB SLI
  • Nvidia GeForce GTX 295 1,792MB
  • Nvidia GeForce GTX 260-216 896MB SLI
  • ATI Radeon HD 4870 1GB CrossFire
  • ATI Radeon HD 4870 X2 2GB
  • Zotac GeForce GTX 285 1GB AMP!
  • Nvidia GeForce GTX 285 1GB
  • HIS ATI Radeon HD 4870 1GB IceQ4+ Turbo
  • ATI Radeon HD 4870 512MB
    • 89.5
    • 57.0
    • 83.1
    • 51.0
    • 79.9
    • 49.0
    • 61.9
    • 36.0
    • 58.7
    • 33.0
    • 56.6
    • 33.0
    • 55.2
    • 33.0
    • 49.5
    • 29.0
    • 43.9
    • 25.0
    • 37.6
    • 20.0
    • 36.8
    • 20.0
    • 36.6
    • 20.0
20
30
40
50
60
70
80
90
Frames Per Second
  • Average
  • Minimum
Crysis
1,280 x 1,024 4xAA 16xAF, DirectX 10, High Quality
    • 77.2
    • 48.0
    • 70.4
    • 44.0
    • 67.7
    • 42.0
    • 53.9
    • 29.0
    • 50.6
    • 28.0
    • 48.6
    • 29.0
    • 46.8
    • 28.0
    • 42.1
    • 24.0
    • 36.9
    • 21.0
    • 31.9
    • 16.0
    • 30.4
    • 16.0
    • 30.4
    • 16.0
20
30
40
50
60
70
80
Frames Per Second
  • Average
  • Minimum
Crysis
1,680 x 1,050 0xAA 16xAF, DirectX 10, High Quality
    • 74.7
    • 47.0
    • 69.2
    • 45.0
    • 66.8
    • 42.0
    • 51.5
    • 30.0
    • 49.0
    • 29.0
    • 46.8
    • 29.0
    • 45.3
    • 27.0
    • 40.9
    • 25.0
    • 36.0
    • 21.0
    • 30.7
    • 18.0
    • 29.8
    • 16.0
    • 29.2
    • 16.0
20
30
40
50
60
70
80
Frames Per Second
  • Average
  • Minimum
Crysis
1,680 x 1,050 4xAA 16xAF, DirectX 10, High Quality
    • 64.6
    • 42.0
    • 56.0
    • 37.0
    • 54.2
    • 36.0
    • 43.1
    • 24.0
    • 41.6
    • 25.0
    • 39.9
    • 25.0
    • 38.3
    • 24.0
    • 35.1
    • 21.0
    • 29.7
    • 18.0
    • 25.8
    • 14.0
    • 24.4
    • 13.0
    • 24.3
    • 13.0
20
30
40
50
60
70
Frames Per Second
  • Average
  • Minimum
Crysis
1,920 x 1,200 0xAA 16xAF, DirectX 10, High Quality
    • 62.1
    • 39.0
    • 57.4
    • 36.0
    • 54.6
    • 34.0
    • 48.1
    • 28.0
    • 45.8
    • 27.0
    • 38.5
    • 23.0
    • 37.1
    • 22.0
    • 33.5
    • 20.0
    • 29.2
    • 17.0
    • 28.2
    • 16.0
    • 27.3
    • 15.0
    • 27.1
    • 15.0
20
30
40
50
60
Frames Per Second
  • Average
  • Minimum
Crysis
1,920 x 1,200 2xAA 16xAF, DirectX 10, High Quality
    • 56.8
    • 36.0
    • 49.5
    • 27.0
    • 47.6
    • 31.0
    • 44.4
    • 26.0
    • 42.2
    • 25.0
    • 35.1
    • 21.0
    • 33.9
    • 21.0
    • 30.5
    • 18.0
    • 26.3
    • 15.0
    • 26.2
    • 15.0
    • 25.0
    • 14.0
    • 24.6
    • 14.0
20
30
40
50
60
Frames Per Second
  • Average
  • Minimum
Dropping the in-game settings down to high quality affords a better gameplay experience on the HIS Radeon HD 4870 1GB IceQ4+ Turbo and it'll enable you to increase the highest playable settings to 1,680 x 1,050 with 0xAA and 16xAF applied. At this setting though, it's a good 17 percent slower than the GeForce GTX 260-216 896MB and, what's more, the competition from Nvidia has enough juice to deliver acceptable gameplay with 4xAA enabled as well although you'd probably settle on 2xAA for a much smoother experience.
